Lots O Philcos at K-town.. My haul
Hey john,
It was ok, watery and misty. In the mornings and that did affect a few radios like my 90. The dome was flat the first day, now I have to glue it down. Got a little better as the day progressed.
RE: Lots O Philcos at K-town - by OldRestorer - 05-09-2014, 09:44 PM
RE: Lots O Philcos at K-town - by Ron Ramirez - 05-09-2014, 09:51 PM
RE: Lots O Philcos at K-town - by morzh - 05-09-2014, 10:04 PM
RE: Lots O Philcos at K-town - by BrendaAnnD - 05-09-2014, 10:58 PM
RE: Lots O Philcos at K-town - by tab10672 - 05-09-2014, 11:54 PM
RE: Lots O Philcos at K-town.. My haul - by morzh - 05-10-2014, 03:23 PM
RE: Lots O Philcos at K-town.. My haul - by JimZ - 05-10-2014, 06:18 PM
RE: Lots O Philcos at K-town.. My haul - by OldRestorer - 05-11-2014, 10:34 AM
RE: Lots O Philcos at K-town.. My haul - by Arran - 05-12-2014, 11:44 PM
RE: Lots O Philcos at K-town.. My haul - by morzh - 05-14-2014, 08:48 AM
Philco 91 Tuning Condenser
There are currently 8881 online users. [Complete List]
» 2 Member(s) | 8879 Guest(s)
