Chassis Detailing or not
Warren, the biggest problem is that by the time all of the scratches are gone so is a good part of the original plating and now the chassis will be more prone to rusting unless painted or treated in some way. I do understand that sometimes a chassis is so rusty or mouse damaged that a person has to do something but myself I avoid those sets. I do have some Scott's that have some pitting and rusting, I will strip them down to the bare chassis and have them replated.
Gregb
Chassis Detailing or not - by 462ron - 05-09-2014, 09:00 PM
RE: Chassis Detailing or not - by 37silverstreak - 05-09-2014, 09:22 PM
RE: Chassis Detailing or not - by Ron Ramirez - 05-09-2014, 09:57 PM
RE: Chassis Detailing or not - by gregb - 05-09-2014, 11:06 PM
RE: Chassis Detailing or not - by 462ron - 05-10-2014, 12:55 AM
RE: Chassis Detailing or not - by Eric Adams - 05-10-2014, 10:46 AM
RE: Chassis Detailing or not - by Mondial - 05-10-2014, 11:04 AM
RE: Chassis Detailing or not - by OldRestorer - 05-10-2014, 08:58 PM
RE: Chassis Detailing or not - by exray - 05-10-2014, 09:49 PM
RE: Chassis Detailing or not - by gregb - 05-10-2014, 11:44 PM
RE: Chassis Detailing or not - by Eric Adams - 05-10-2014, 11:51 PM
RE: Chassis Detailing or not - by gregb - 05-11-2014, 12:03 AM
RE: Chassis Detailing or not - by Arran - 05-11-2014, 12:09 AM
RE: Chassis Detailing or not - by Warren - 05-11-2014, 02:40 AM
RE: Chassis Detailing or not - by PhilcoJohn - 05-11-2014, 07:56 AM
RE: Chassis Detailing or not - by codefox1 - 05-11-2014, 09:34 AM
RE: Chassis Detailing or not - by gregb - 05-11-2014, 10:56 AM
RE: Chassis Detailing or not - by Groundhog74 - 05-11-2014, 06:06 PM
RE: Chassis Detailing or not - by 462ron - 05-11-2014, 06:43 PM
RE: Chassis Detailing or not - by Warren - 05-12-2014, 01:30 AM
RE: Chassis Detailing or not - by codefox1 - 05-12-2014, 11:33 AM
RE: Chassis Detailing or not - by gregb - 05-12-2014, 11:47 AM
RE: Chassis Detailing or not - by Warren - 05-12-2014, 02:35 PM
RE: Chassis Detailing or not - by Jamie - 05-12-2014, 04:26 PM
There are currently 10263 online users. [Complete List]
» 2 Member(s) | 10261 Guest(s)
