Knob shaft doesn't turn tuning coil
The shaft is loose on the coil. The string itself seems to be fine. Most of the time, the shaft just turns freely and does not catch to turn the coil.
RE: Knob shaft doesn't turn tuning coil - by captainslack - 05-11-2014, 11:12 PM
There are currently 11378 online users. [Complete List]
» 2 Member(s) | 11376 Guest(s)
