  • 1 Vote(s) - 5 Average
111 grillcloth cardboard frame.
John
I have Michaels 2 miles from my place.
Yes in fact when I looked at the backing board I was not sure how these beams can add much rigidity to the whole board as it is a square with a circle cut inside and the remainder of material is pretty wide as you can see from the photos.
I thought maybe the beams are there just to support the cloth in the middle a little.
I will try to repair it. I have baking parchment paper, will use it for keeping glue out.
What is the "matting material for large prints"? Oh, do you mean that piece of cardboard that is put against the photo in the fram to keep it flat against the glass?
111 grillcloth cardboard frame. - by morzh - 05-11-2014, 09:12 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 01:35 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 10:15 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 11:01 AM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 12:11 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 02:50 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 03:10 PM
RE: 111 grillcloth cardboard frame. - by codefox1 - 05-12-2014, 03:23 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 04:21 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 05:06 PM
RE: 111 grillcloth cardboard frame. - by Jamie - 05-12-2014, 05:19 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-12-2014, 11:23 PM
RE: 111 grillcloth cardboard frame. - by Warren - 05-12-2014, 11:37 PM
RE: 111 grillcloth cardboard frame. - by sam - 05-13-2014, 12:49 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-13-2014, 03:02 PM
RE: 111 grillcloth cardboard frame. - by Jamie - 05-13-2014, 07:07 PM
RE: 111 grillcloth cardboard frame. - by morzh - 05-13-2014, 08:20 PM
RE: 111 grillcloth cardboard frame. - by Joeztech - 06-01-2014, 09:48 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-01-2014, 09:52 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 02:09 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 03:33 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-02-2014, 03:47 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-02-2014, 11:22 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-03-2014, 08:56 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-07-2014, 08:34 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-07-2014, 10:36 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-08-2014, 12:17 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-08-2014, 12:38 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 10:37 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 09:00 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-18-2014, 09:09 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-18-2014, 11:14 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 07:27 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 09:37 AM
RE: 111 grillcloth cardboard frame. - by morzh - 06-19-2014, 03:18 PM
RE: 111 grillcloth cardboard frame. - by Warren - 06-19-2014, 05:36 PM
RE: 111 grillcloth cardboard frame. - by morzh - 06-20-2014, 11:49 AM
