Knob shaft doesn't turn tuning coil
You can move the tension spring one position closer to the center if this available, and borrow a chunk of rosin from any fiddler and touch up the string segment that is slipping.
RE: Knob shaft doesn't turn tuning coil - by codefox1 - 05-12-2014, 11:36 AM
There are currently 11423 online users. [Complete List]
» 2 Member(s) | 11421 Guest(s)
