Knob shaft doesn't turn tuning coil
Thanks, Ron! I'll print that out before my buddy & I have another look at it.
RE: Knob shaft doesn't turn tuning coil - by captainslack - 05-12-2014, 04:04 PM
There are currently 10545 online users. [Complete List]
» 3 Member(s) | 10542 Guest(s)
