Field coil repair.
So, need to repair a few field coils.
The speaker shop has moved and not accepting orders 'till some time in the fall.
The Sound Remedy don't do field coils.
I called other guys from the local list - they do not do field coils.
The guy from the Lake Hiawatha, John, so far did not answer. I left him a message again, but I still do not know if he does field coils.
Where do I turn?
Field coil repair. - by morzh - 05-13-2014, 05:45 PM
RE: Field coil repair. - by vinzer - 05-13-2014, 10:56 PM
RE: Field coil repair. - by morzh - 05-13-2014, 11:13 PM
RE: Field coil repair. - by vinzer - 05-14-2014, 12:55 PM
RE: Field coil repair. - by Ron Ramirez - 05-14-2014, 02:22 PM
RE: Field coil repair. - by morzh - 05-14-2014, 04:34 PM
RE: Field coil repair. - by Ron Ramirez - 05-14-2014, 04:51 PM
RE: Field coil repair. - by morzh - 05-14-2014, 05:01 PM
RE: Field coil repair. - by Ron Ramirez - 05-14-2014, 05:02 PM
RE: Field coil repair. - by morzh - 05-14-2014, 05:08 PM
RE: Field coil repair. - by Allen in SB - 05-15-2014, 01:23 AM
RE: Field coil repair. - by morzh - 05-15-2014, 09:54 AM
RE: Field coil repair. - by morzh - 05-15-2014, 09:46 PM
RE: Field coil repair. - by vinzer - 05-15-2014, 09:54 PM
RE: Field coil repair. - by morzh - 05-15-2014, 10:32 PM
RE: Field coil repair. - by morzh - 05-15-2014, 10:35 PM
RE: Field coil repair. - by Ron Ramirez - 05-16-2014, 05:26 AM
RE: Field coil repair. - by morzh - 05-16-2014, 09:49 AM
RE: Field coil repair. - by Ron Ramirez - 05-16-2014, 10:22 AM
RE: Field coil repair. - by morzh - 05-16-2014, 01:56 PM
RE: Field coil repair. - by Ron Ramirez - 05-16-2014, 04:48 PM
RE: Field coil repair. - by morzh - 05-18-2014, 09:36 PM
RE: Field coil repair. - by Ron Ramirez - 05-18-2014, 09:41 PM
RE: Field coil repair. - by morzh - 05-18-2014, 09:45 PM
RE: Field coil repair. - by Warren - 05-18-2014, 10:50 PM
RE: Field coil repair. - by morzh - 05-18-2014, 11:00 PM
RE: Field coil repair. - by sam - 05-19-2014, 12:37 AM
RE: Field coil repair. - by Ron Ramirez - 05-19-2014, 05:52 AM
RE: Field coil repair. - by morzh - 05-19-2014, 09:51 AM
RE: Field coil repair. - by Jamie - 05-20-2014, 12:18 PM
RE: Field coil repair. - by K7Sparky - 05-21-2014, 10:27 PM
RE: Field coil repair. - by K7Sparky - 05-22-2014, 08:00 AM
RE: Field coil repair. - by morzh - 05-22-2014, 08:45 AM
RE: Field coil repair. - by K7Sparky - 05-22-2014, 02:57 PM
RE: Field coil repair. - by morzh - 05-22-2014, 03:04 PM
RE: Field coil repair. - by K7Sparky - 05-22-2014, 03:59 PM
RE: Field coil repair. - by Ron Ramirez - 05-22-2014, 06:15 PM
RE: Field coil repair. - by Warren - 05-22-2014, 08:06 PM
RE: Field coil repair. - by Raleigh - 05-25-2014, 04:00 PM
RE: Field coil repair. - by morzh - 05-28-2014, 01:35 PM
RE: Field coil repair. - by K7Sparky - 05-28-2014, 02:35 PM
RE: Field coil repair. - by morzh - 06-27-2014, 09:44 PM
RE: Field coil repair. - by morzh - 06-28-2014, 09:39 AM
RE: Field coil repair. - by K7Sparky - 06-29-2014, 07:17 PM
RE: Field coil repair. - by morzh - 06-29-2014, 07:56 PM
RE: Field coil repair. - by Arran - 06-29-2014, 11:20 PM
RE: Field coil repair. - by morzh - 06-30-2014, 08:26 AM
There are currently 7860 online users. [Complete List]
» 5 Member(s) | 7855 Guest(s)
AvatarAvatarAvatarAvatar
