Lots O Philcos at K-town.. My haul
Kirk,
Nice haul on the radios.
As Arran said, you can find almost anything you want in veneer on Ebay. I just picked up these 5 pieces of 1 ft by 8ft walnut veneer for $25 + shipping.
http://www.ebay.com/itm/Wood-Veneer-Waln...true&rt=nc
Gene
RE: Lots O Philcos at K-town - by OldRestorer - 05-09-2014, 09:44 PM
RE: Lots O Philcos at K-town - by Ron Ramirez - 05-09-2014, 09:51 PM
RE: Lots O Philcos at K-town - by morzh - 05-09-2014, 10:04 PM
RE: Lots O Philcos at K-town - by BrendaAnnD - 05-09-2014, 10:58 PM
RE: Lots O Philcos at K-town - by tab10672 - 05-09-2014, 11:54 PM
RE: Lots O Philcos at K-town.. My haul - by morzh - 05-10-2014, 03:23 PM
RE: Lots O Philcos at K-town.. My haul - by JimZ - 05-10-2014, 06:18 PM
RE: Lots O Philcos at K-town.. My haul - by Arran - 05-12-2014, 11:44 PM
RE: Lots O Philcos at K-town.. My haul - by morzh - 05-14-2014, 08:48 AM
RE: Lots O Philcos at K-town.. My haul - by Gene Pederson - 05-14-2014, 11:06 AM
