Philco 90 Audio Transformer
(I do not know where to find data on 2848 xfmr).
Well, just find the ends of your primary.
A Pushpull for 2x45 impedance is about the same as 1x47.
If it was a pushpull transformer, the ends of it were probably connected to the anodes, use those.
Here what you could do to make sure:
1. Unsolder the voice coil.
2. Using a Variac and a Voltmeter, supply a goodly amount of AC voltage to the full primary (to P-P ends). Say, 60V. Measure the output by the Voltmeter out of the secondary. It should be close to 0.6V.
3. If not, find a tap and an end of the primary that will give you 97:1 ratio, that is 60V fed to primary gives you about 0.6V output. These are your contacts to use.
Another alternative: at some point you will need a Push-Pull xfmr, so save this one and get an SE transformer with 97:1 ratio. (well, it is 100:1 in Philco 20).
Philco 90 Audio Transformer - by nuke - 05-12-2014, 09:47 PM
RE: Philco 90 Audio Transformer - by morzh - 05-12-2014, 11:19 PM
RE: Philco 90 Audio Transformer - by nuke - 05-15-2014, 09:10 AM
RE: Philco 90 Audio Transformer - by morzh - 05-15-2014, 09:59 AM
RE: Philco 90 Audio Transformer - by Ron Ramirez - 05-15-2014, 10:35 AM
RE: Philco 90 Audio Transformer - by nuke - 05-15-2014, 11:08 AM
RE: Philco 90 Audio Transformer - by morzh - 05-15-2014, 12:13 PM
RE: Philco 90 Audio Transformer - by nuke - 06-08-2014, 07:31 PM
RE: Philco 90 Audio Transformer - by morzh - 06-08-2014, 08:07 PM
RE: Philco 90 Audio Transformer - by nuke - 06-08-2014, 09:21 PM
RE: Philco 90 Audio Transformer - by morzh - 06-08-2014, 10:07 PM
RE: Philco 90 Audio Transformer - by nuke - 06-11-2014, 10:38 PM
RE: Philco 90 Audio Transformer - by nuke - 07-01-2014, 10:15 PM
RE: Philco 90 Audio Transformer - by Arran - 07-01-2014, 11:02 PM
RE: Philco 90 Audio Transformer - by nuke - 07-01-2014, 11:05 PM
There are currently 6335 online users. [Complete List]
» 2 Member(s) | 6333 Guest(s)
