Philco 90 with Twin 47 Tubes in PP
#33
That bushing, as you call it, actually acts like a thrust bearing between the dial drive and the bracket. The spring is there to maintain pressure between the thrust bearing, the edge of the dial, and that T shaped sleeve on the other side, the pressure it applies is horizontal so I don't think it caused the shaft to wear as it did. I don't know what to suggest as a means of dealing with the worn shaft, welding it and then machining it down in a lathe would be the best method, unless you could fit a sleeve over it. If these were designed properly they would have used a bronze or brass bushing for the shaft to rotate inside of rather then a thin edge of a sheet metal bracket, this was normal construction with tuning shafts in later sets.
Philco 90 with Twin 47 Tubes in PP - by joybird - 05-05-2014, 12:00 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 03:39 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 04:55 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-05-2014, 06:23 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-05-2014, 07:05 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 07:45 PM
RE: Philco 90 with Twin 47 Tubes in PP - by gregb - 05-05-2014, 09:45 PM
RE: Philco 90 with Twin 47 Tubes in PP - by gregb - 05-05-2014, 09:49 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 10:37 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-07-2014, 02:21 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-07-2014, 11:48 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-14-2014, 11:15 AM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-14-2014, 02:11 PM
RE: Philco 90 with Twin 47 Tubes in PP - by gregb - 05-14-2014, 04:22 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-15-2014, 01:26 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-16-2014, 01:09 AM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-17-2014, 02:40 AM
There are currently 10920 online users. [Complete List]
» 3 Member(s) | 10917 Guest(s)
