Philco 90 with Twin 47 Tubes in PP
#34
I am going to try and insert the shown BUSHING in the Bracket
Hoping for a nice press fit.
Bob T
Philco 90 with Twin 47 Tubes in PP - by joybird - 05-05-2014, 12:00 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 03:39 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 04:55 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-05-2014, 06:23 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-05-2014, 07:05 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 07:45 PM
RE: Philco 90 with Twin 47 Tubes in PP - by gregb - 05-05-2014, 09:45 PM
RE: Philco 90 with Twin 47 Tubes in PP - by gregb - 05-05-2014, 09:49 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-05-2014, 10:37 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-07-2014, 02:21 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-07-2014, 11:48 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-14-2014, 11:15 AM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-14-2014, 02:11 PM
RE: Philco 90 with Twin 47 Tubes in PP - by gregb - 05-14-2014, 04:22 PM
RE: Philco 90 with Twin 47 Tubes in PP - by morzh - 05-15-2014, 01:26 PM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-16-2014, 01:09 AM
RE: Philco 90 with Twin 47 Tubes in PP - by joybird - 05-16-2014, 06:28 AM
RE: Philco 90 with Twin 47 Tubes in PP - by Arran - 05-17-2014, 02:40 AM
There are currently 11419 online users. [Complete List]
» 2 Member(s) | 11417 Guest(s)
