Field coil repair.
The cone might be glued to the speaker frame on the outer edge of the cone. I've seen some 20/70/90 speakers that had the outer edge glued to the frame, and some that weren't (or else the glue turned loose over the decades). So, proceed with caution.
Field coil repair. - by morzh - 05-13-2014, 05:45 PM
RE: Field coil repair. - by vinzer - 05-13-2014, 10:56 PM
RE: Field coil repair. - by morzh - 05-13-2014, 11:13 PM
RE: Field coil repair. - by vinzer - 05-14-2014, 12:55 PM
RE: Field coil repair. - by Ron Ramirez - 05-14-2014, 02:22 PM
RE: Field coil repair. - by morzh - 05-14-2014, 04:34 PM
RE: Field coil repair. - by Ron Ramirez - 05-14-2014, 04:51 PM
RE: Field coil repair. - by morzh - 05-14-2014, 05:01 PM
RE: Field coil repair. - by Ron Ramirez - 05-14-2014, 05:02 PM
RE: Field coil repair. - by morzh - 05-14-2014, 05:08 PM
RE: Field coil repair. - by Allen in SB - 05-15-2014, 01:23 AM
RE: Field coil repair. - by morzh - 05-15-2014, 09:54 AM
RE: Field coil repair. - by morzh - 05-15-2014, 09:46 PM
RE: Field coil repair. - by vinzer - 05-15-2014, 09:54 PM
RE: Field coil repair. - by morzh - 05-15-2014, 10:32 PM
RE: Field coil repair. - by morzh - 05-15-2014, 10:35 PM
RE: Field coil repair. - by Ron Ramirez - 05-16-2014, 05:26 AM
RE: Field coil repair. - by morzh - 05-16-2014, 09:49 AM
RE: Field coil repair. - by Ron Ramirez - 05-16-2014, 10:22 AM
RE: Field coil repair. - by morzh - 05-16-2014, 01:56 PM
RE: Field coil repair. - by Ron Ramirez - 05-16-2014, 04:48 PM
RE: Field coil repair. - by morzh - 05-18-2014, 09:36 PM
RE: Field coil repair. - by Ron Ramirez - 05-18-2014, 09:41 PM
RE: Field coil repair. - by morzh - 05-18-2014, 09:45 PM
RE: Field coil repair. - by Warren - 05-18-2014, 10:50 PM
RE: Field coil repair. - by morzh - 05-18-2014, 11:00 PM
RE: Field coil repair. - by sam - 05-19-2014, 12:37 AM
RE: Field coil repair. - by Ron Ramirez - 05-19-2014, 05:52 AM
RE: Field coil repair. - by morzh - 05-19-2014, 09:51 AM
RE: Field coil repair. - by Jamie - 05-20-2014, 12:18 PM
RE: Field coil repair. - by K7Sparky - 05-21-2014, 10:27 PM
RE: Field coil repair. - by K7Sparky - 05-22-2014, 08:00 AM
RE: Field coil repair. - by morzh - 05-22-2014, 08:45 AM
RE: Field coil repair. - by K7Sparky - 05-22-2014, 02:57 PM
RE: Field coil repair. - by morzh - 05-22-2014, 03:04 PM
RE: Field coil repair. - by K7Sparky - 05-22-2014, 03:59 PM
RE: Field coil repair. - by Ron Ramirez - 05-22-2014, 06:15 PM
RE: Field coil repair. - by Warren - 05-22-2014, 08:06 PM
RE: Field coil repair. - by Raleigh - 05-25-2014, 04:00 PM
RE: Field coil repair. - by morzh - 05-28-2014, 01:35 PM
RE: Field coil repair. - by K7Sparky - 05-28-2014, 02:35 PM
RE: Field coil repair. - by morzh - 06-27-2014, 09:44 PM
RE: Field coil repair. - by morzh - 06-28-2014, 09:39 AM
RE: Field coil repair. - by K7Sparky - 06-29-2014, 07:17 PM
RE: Field coil repair. - by morzh - 06-29-2014, 07:56 PM
RE: Field coil repair. - by Arran - 06-29-2014, 11:20 PM
RE: Field coil repair. - by morzh - 06-30-2014, 08:26 AM
Philco 91 Restore Code ??
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
There are currently 3249 online users. [Complete List]
» 3 Member(s) | 3246 Guest(s)
