Suggestions on Cabinet repair
I think Kirk means "no wood filler in place of a veneer chip," not "no grain filler in the veneer repair."
Suggestions on Cabinet repair - by Warren - 05-15-2014, 10:43 PM
RE: Suggestions on Cabinet repair - by Arran - 05-16-2014, 12:51 AM
RE: Suggestions on Cabinet repair - by Warren - 05-16-2014, 03:01 PM
RE: Suggestions on Cabinet repair - by Ron Ramirez - 05-16-2014, 04:50 PM
RE: Suggestions on Cabinet repair - by codefox1 - 05-16-2014, 05:49 PM
RE: Suggestions on Cabinet repair - by vinzer - 05-16-2014, 10:33 PM
RE: Suggestions on Cabinet repair - by Warren - 05-17-2014, 02:43 PM
RE: Suggestions on Cabinet repair - by Arran - 05-18-2014, 02:47 AM
