Radiola 48 chassis restoration
Thanks Jerry, I found that manual the other day and was studying it. I did put up a schematic just now. I was just a little hesitant to jump in to those 4 metal tar cans. Each have 2 to 3 by-pass caps in them. But I will give it a try.
Radiola 48 chassis restoration - by KCMike - 05-16-2014, 01:52 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-16-2014, 05:10 PM
RE: Radiola 48 chassis restoration - by Mondial - 05-16-2014, 09:01 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-17-2014, 10:38 AM
RE: Radiola 48 chassis restoration - by Mondial - 05-17-2014, 02:38 PM
RE: Radiola 48 chassis restoration - by codefox1 - 05-17-2014, 04:26 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-17-2014, 07:42 PM
RE: Radiola 48 chassis restoration - by Arran - 05-17-2014, 10:56 PM
RE: Radiola 48 chassis restoration - by gregb - 05-17-2014, 11:12 PM
RE: Radiola 48 chassis restoration - by gregb - 05-17-2014, 11:23 PM
RE: Radiola 48 chassis restoration - by Arran - 05-18-2014, 12:04 AM
RE: Radiola 48 chassis restoration - by KCMike - 05-18-2014, 04:11 PM
RE: Radiola 48 chassis restoration - by Mondial - 05-18-2014, 04:41 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-18-2014, 05:53 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-18-2014, 09:04 PM
RE: Radiola 48 chassis restoration - by Arran - 05-18-2014, 09:12 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-18-2014, 09:45 PM
RE: Radiola 48 chassis restoration - by Arran - 05-18-2014, 10:04 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-19-2014, 08:19 AM
RE: Radiola 48 chassis restoration - by KCMike - 05-19-2014, 11:51 AM
RE: Radiola 48 chassis restoration - by Mondial - 05-19-2014, 09:00 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-20-2014, 08:49 AM
RE: Radiola 48 chassis restoration - by KCMike - 05-20-2014, 12:26 PM
RE: Radiola 48 chassis restoration - by Mondial - 05-20-2014, 09:26 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-20-2014, 09:45 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-21-2014, 06:06 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-22-2014, 08:47 AM
RE: Radiola 48 chassis restoration - by KCMike - 05-22-2014, 09:54 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-23-2014, 10:08 AM
RE: Radiola 48 chassis restoration - by KCMike - 05-23-2014, 03:53 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-23-2014, 06:20 PM
RE: Radiola 48 chassis restoration - by KCMike - 05-23-2014, 10:05 PM
RE: Radiola 48 chassis restoration - by Arran - 05-24-2014, 03:42 AM
RE: Radiola 48 chassis restoration - by gregb - 05-24-2014, 10:39 AM
There are currently 6068 online users. [Complete List]
» 1 Member(s) | 6067 Guest(s)
