Philco "Ventilator" window fan
I've got a few old Philcos, including a 38-1 console. I came across what I thought was an old Philco radio at a local thrift store. Upon closer look I discovered that it is the Philco Ventilator - a window fan. I can't find much information about these on the web and it seems like they are pretty rare. Does anyone have any idea what these things are worth? The store has it priced at 85.00. It works, all the knobs are there. Cosmetically I would say it's in good condition.
Thanks!
Philco "Ventilator" window fan - by Guest - 09-09-2008, 04:10 PM
Re: Philco "Ventilator" window fan - by Guest - 09-09-2008, 10:48 PM
Re: Philco "Ventilator" window fan - by Guest - 09-12-2008, 06:28 PM
There are currently 8759 online users. [Complete List]
» 3 Member(s) | 8756 Guest(s)
