TUBE TESTER - WHAT TYPE?
ODPILOT, you will get more answers from that question and they will all vary. I have a Precision 10-12 which is a low end tube tester but will test any tube I can come up with. Testing is a word that is rather ambiguous as some test more factors than others. Mine is an emission tester but it does handle dead and shorted tubes which I'm most interested in and provide an idea of emission of the tube. Others will provide more precise information on tube function. I will say radio tubes that test weak on any tester seem to work just fine. All bets are off on oscillator tubes as no reasonably priced tester will tell you if they are going to work at higher frequencies. The best tester is the radio with a known good tube that works in another radio.
If you wish to match output tubes in a high end piece of audio equipment, the more expensive ones are nice. I don't need that just a rough test.
Good luck on your search and match your needs to a product. Particular emphasis on will it handle your tubes. Often "new" ones won't handle tubes from the 30s due to sockets for them not being there.
Happy with what mine does as a rough check and to make certain I don't plug a tube in that is going to hurt something else in the radio.
Jerry
TUBE TESTER - WHAT TYPE? - by ODPILOT - 05-17-2014, 01:49 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 03:36 PM
RE: TUBE TESTER - WHAT TYPE? - by codefox1 - 05-17-2014, 04:35 PM
RE: TUBE TESTER - WHAT TYPE? - by morzh - 05-17-2014, 04:48 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 05:29 PM
RE: TUBE TESTER - WHAT TYPE? - by Phlogiston - 05-17-2014, 07:26 PM
RE: TUBE TESTER - WHAT TYPE? - by morzh - 05-17-2014, 08:28 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 08:50 PM
RE: TUBE TESTER - WHAT TYPE? - by Eliot Ness - 05-18-2014, 09:15 AM
RE: TUBE TESTER - WHAT TYPE? - by GarySP - 05-18-2014, 07:40 PM
RE: TUBE TESTER - WHAT TYPE? - by Ron Ramirez - 05-18-2014, 08:50 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-19-2014, 12:03 PM
RE: TUBE TESTER - WHAT TYPE? - by Chuck Schwark - 05-19-2014, 03:42 PM
RE: TUBE TESTER - WHAT TYPE? - by Ron Ramirez - 05-19-2014, 03:49 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-19-2014, 05:47 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-19-2014, 10:22 PM
RE: TUBE TESTER - WHAT TYPE? - by Jamie - 05-20-2014, 11:51 AM
RE: TUBE TESTER - WHAT TYPE? - by K7Sparky - 05-21-2014, 12:42 PM
RE: TUBE TESTER - WHAT TYPE? - by Eric T - 05-22-2014, 02:04 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-23-2014, 09:30 AM
RE: TUBE TESTER - WHAT TYPE? - by DeckApe - 05-27-2014, 05:00 PM
RE: TUBE TESTER - WHAT TYPE? - by K7Sparky - 05-27-2014, 07:37 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-27-2014, 09:39 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-27-2014, 10:29 PM
RE: TUBE TESTER - WHAT TYPE? - by Arran - 05-27-2014, 10:44 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-28-2014, 10:44 AM
RE: TUBE TESTER - WHAT TYPE? - by Arran - 05-30-2014, 01:57 AM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-30-2014, 10:16 AM
RE: TUBE TESTER - WHAT TYPE? - by Alan Douglas - 05-31-2014, 09:09 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-31-2014, 10:35 PM
Philco 91 Restore Code ??
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
There are currently 2947 online users. [Complete List]
» 3 Member(s) | 2944 Guest(s)
