Kirk's 84
If it is this it I guess it never had a nut, don't worry about it. I will get one. And the dial pointer was missing so I don't think you could do alignment. If it does not pick up the Australian opera station I won't be too sad.
Kirk's 84 - by morzh - 05-15-2014, 09:04 PM
RE: Kirk's 84 - by vinzer - 05-15-2014, 09:52 PM
RE: Kirk's 84 - by morzh - 05-15-2014, 11:11 PM
RE: Kirk's 84 - by Ron Ramirez - 05-16-2014, 05:31 AM
RE: Kirk's 84 - by morzh - 05-16-2014, 09:51 AM
RE: Kirk's 84 - by morzh - 05-17-2014, 01:17 PM
RE: Kirk's 84 - by Radioroslyn - 05-17-2014, 04:20 PM
RE: Kirk's 84 - by morzh - 05-17-2014, 04:41 PM
RE: Kirk's 84 - by morzh - 05-17-2014, 06:16 PM
RE: Kirk's 84 - by OldRestorer - 05-17-2014, 07:31 PM
RE: Kirk's 84 - by morzh - 05-17-2014, 08:16 PM
RE: Kirk's 84 - by morzh - 05-17-2014, 10:56 PM
RE: Kirk's 84 - by OldRestorer - 05-18-2014, 06:17 AM
RE: Kirk's 84 - by morzh - 05-18-2014, 11:05 AM
RE: Kirk's 84 - by Ron Ramirez - 05-18-2014, 03:20 PM
RE: Kirk's 84 - by morzh - 05-18-2014, 03:34 PM
RE: Kirk's 84 - by Radioroslyn - 05-18-2014, 05:21 PM
RE: Kirk's 84 - by Ron Ramirez - 05-18-2014, 06:06 PM
RE: Kirk's 84 - by morzh - 05-18-2014, 06:12 PM
RE: Kirk's 84 - by sam - 05-18-2014, 06:18 PM
RE: Kirk's 84 - by morzh - 05-18-2014, 07:46 PM
RE: Kirk's 84 - by morzh - 05-18-2014, 07:52 PM
There are currently 3958 online users. [Complete List]
» 1 Member(s) | 3957 Guest(s)
