Philco 2W resistors mystery
I have seen the same thing more in the higher-wattage Philco carbon resistors than in the smaller rated ones. Why they decrease vice increase in value I do not know.
As a rule I replace any resistor more than 10% off. I figure that it will continue to change value as it continues to age.
Philco 2W resistors mystery - by morzh - 05-17-2014, 11:06 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-18-2014, 09:56 AM
RE: Philco 2W resistors mystery - by TA Forbes - 05-18-2014, 10:07 AM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 11:03 AM
RE: Philco 2W resistors mystery - by Ron Ramirez - 05-18-2014, 03:25 PM
RE: Philco 2W resistors mystery - by Radioroslyn - 05-18-2014, 05:26 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-18-2014, 06:01 PM
RE: Philco 2W resistors mystery - by Ron Ramirez - 05-18-2014, 06:02 PM
RE: Philco 2W resistors mystery - by PAradiogeek - 05-18-2014, 07:25 PM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 07:41 PM
RE: Philco 2W resistors mystery - by GarySP - 05-18-2014, 07:44 PM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 07:53 PM
RE: Philco 2W resistors mystery - by Jamie - 05-20-2014, 12:17 PM
RE: Philco 2W resistors mystery - by morzh - 05-20-2014, 01:21 PM
RE: Philco 2W resistors mystery - by gregb - 05-20-2014, 02:35 PM
RE: Philco 2W resistors mystery - by Jamie - 05-20-2014, 03:37 PM
RE: Philco 2W resistors mystery - by TA Forbes - 05-20-2014, 09:51 PM
RE: Philco 2W resistors mystery - by Raleigh - 05-24-2014, 05:49 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-26-2014, 08:04 AM
RE: Philco 2W resistors mystery - by Joeztech - 06-01-2014, 09:29 PM
RE: Philco 2W resistors mystery - by Arran - 06-01-2014, 10:32 PM
There are currently 11277 online users. [Complete List]
» 2 Member(s) | 11275 Guest(s)
