Philco 2W resistors mystery
For the past few years, I just automatically replace capacitors and resistors in the vintage Philco sets. The old carbon composition resistors are known to drift, either up or down, so I feel that I might as well avoid any issues by replacing them and being done with it.
Philco 2W resistors mystery - by morzh - 05-17-2014, 11:06 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-18-2014, 09:56 AM
RE: Philco 2W resistors mystery - by TA Forbes - 05-18-2014, 10:07 AM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 11:03 AM
RE: Philco 2W resistors mystery - by Ron Ramirez - 05-18-2014, 03:25 PM
RE: Philco 2W resistors mystery - by Radioroslyn - 05-18-2014, 05:26 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-18-2014, 06:01 PM
RE: Philco 2W resistors mystery - by Ron Ramirez - 05-18-2014, 06:02 PM
RE: Philco 2W resistors mystery - by PAradiogeek - 05-18-2014, 07:25 PM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 07:41 PM
RE: Philco 2W resistors mystery - by GarySP - 05-18-2014, 07:44 PM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 07:53 PM
RE: Philco 2W resistors mystery - by Jamie - 05-20-2014, 12:17 PM
RE: Philco 2W resistors mystery - by morzh - 05-20-2014, 01:21 PM
RE: Philco 2W resistors mystery - by gregb - 05-20-2014, 02:35 PM
RE: Philco 2W resistors mystery - by Jamie - 05-20-2014, 03:37 PM
RE: Philco 2W resistors mystery - by TA Forbes - 05-20-2014, 09:51 PM
RE: Philco 2W resistors mystery - by Raleigh - 05-24-2014, 05:49 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-26-2014, 08:04 AM
RE: Philco 2W resistors mystery - by Joeztech - 06-01-2014, 09:29 PM
RE: Philco 2W resistors mystery - by Arran - 06-01-2014, 10:32 PM
There are currently 10228 online users. [Complete List]
» 3 Member(s) | 10225 Guest(s)
