15 (X) tubes
The June of 1932 15 uses 44s and 37s. I don't think I have ever seen a 37 as a globe tube, maybe the 44 and certainly the 42s in the PP output.
Do you think there was much likelihood of this radio have some/any globe tubes?
Almost all of the tubes in it are STs with printed logos. So they are nice, but wrong for a restored unit.
Man, this thing has some big iron.
15 (X) tubes - by Phlogiston - 05-18-2014, 07:10 PM
RE: 15 (X) tubes - by Mondial - 05-18-2014, 08:38 PM
RE: 15 (X) tubes - by Ron Ramirez - 05-18-2014, 08:43 PM
RE: 15 (X) tubes - by klondike98 - 05-18-2014, 10:24 PM
RE: 15 (X) tubes - by gregb - 05-18-2014, 11:49 PM
RE: 15 (X) tubes - by Phlogiston - 05-19-2014, 10:47 AM
RE: 15 (X) tubes - by TA Forbes - 05-19-2014, 11:24 AM
RE: 15 (X) tubes - by Arran - 05-20-2014, 09:44 PM
RE: 15 (X) tubes - by TA Forbes - 05-20-2014, 09:49 PM
RE: 15 (X) tubes - by gregb - 05-20-2014, 11:26 PM
RE: 15 (X) tubes - by Phlogiston - 05-21-2014, 02:22 AM
RE: 15 (X) tubes - by gregb - 05-21-2014, 08:47 AM
RE: 15 (X) tubes - by Bob Andersen - 05-24-2014, 02:57 PM
Philco 91 Tuning Condenser
There are currently 4666 online users. [Complete List]
» 1 Member(s) | 4665 Guest(s)
