TUBE TESTER - WHAT TYPE?
Hello ODPILOT, I have to concur with the opinions given. To find the basic functionality of a tube, an emission tester like an Eico 625 or a Heathkit tester will get you into the church. If you get to the point where you are looking to get into a particular pew in that church, then you're looking at getting a mutual conductance tester. Regardless what avenue you take, a tester is only as good as its' calibration. Gas and short tests are just as important as output values. Just my two cents worth... Take care, Gary.
TUBE TESTER - WHAT TYPE? - by ODPILOT - 05-17-2014, 01:49 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 03:36 PM
RE: TUBE TESTER - WHAT TYPE? - by codefox1 - 05-17-2014, 04:35 PM
RE: TUBE TESTER - WHAT TYPE? - by morzh - 05-17-2014, 04:48 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 05:29 PM
RE: TUBE TESTER - WHAT TYPE? - by Phlogiston - 05-17-2014, 07:26 PM
RE: TUBE TESTER - WHAT TYPE? - by morzh - 05-17-2014, 08:28 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 08:50 PM
RE: TUBE TESTER - WHAT TYPE? - by Eliot Ness - 05-18-2014, 09:15 AM
RE: TUBE TESTER - WHAT TYPE? - by GarySP - 05-18-2014, 07:40 PM
RE: TUBE TESTER - WHAT TYPE? - by Ron Ramirez - 05-18-2014, 08:50 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-19-2014, 12:03 PM
RE: TUBE TESTER - WHAT TYPE? - by Chuck Schwark - 05-19-2014, 03:42 PM
RE: TUBE TESTER - WHAT TYPE? - by Ron Ramirez - 05-19-2014, 03:49 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-19-2014, 05:47 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-19-2014, 10:22 PM
RE: TUBE TESTER - WHAT TYPE? - by Jamie - 05-20-2014, 11:51 AM
RE: TUBE TESTER - WHAT TYPE? - by K7Sparky - 05-21-2014, 12:42 PM
RE: TUBE TESTER - WHAT TYPE? - by Eric T - 05-22-2014, 02:04 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-23-2014, 09:30 AM
RE: TUBE TESTER - WHAT TYPE? - by DeckApe - 05-27-2014, 05:00 PM
RE: TUBE TESTER - WHAT TYPE? - by K7Sparky - 05-27-2014, 07:37 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-27-2014, 09:39 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-27-2014, 10:29 PM
RE: TUBE TESTER - WHAT TYPE? - by Arran - 05-27-2014, 10:44 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-28-2014, 10:44 AM
RE: TUBE TESTER - WHAT TYPE? - by Arran - 05-30-2014, 01:57 AM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-30-2014, 10:16 AM
RE: TUBE TESTER - WHAT TYPE? - by Alan Douglas - 05-31-2014, 09:09 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-31-2014, 10:35 PM
Philco 91 Restore Code ??
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
There are currently 3228 online users. [Complete List]
» 2 Member(s) | 3226 Guest(s)
