Kirk's 84
Sam
It's a great idea. Except I do not have the bolt.
I am not sure what it is. Looks like smaler than 4-40, and I ave an old pot where the lugs are secured wit the nuts of the same dameter but he thread does not mayc- once the nut goes full depth it stops.
Otherwse I thouht to do exact same thing.
I also thought a softer plastic would self-tap if drilled and forced to the bolt but I am no sure where to get the pastic....should be like a nylon, I have none at home.
Kirk's 84 - by morzh - 05-15-2014, 09:04 PM
RE: Kirk's 84 - by vinzer - 05-15-2014, 09:52 PM
RE: Kirk's 84 - by morzh - 05-15-2014, 11:11 PM
RE: Kirk's 84 - by Ron Ramirez - 05-16-2014, 05:31 AM
RE: Kirk's 84 - by morzh - 05-16-2014, 09:51 AM
RE: Kirk's 84 - by morzh - 05-17-2014, 01:17 PM
RE: Kirk's 84 - by Radioroslyn - 05-17-2014, 04:20 PM
RE: Kirk's 84 - by morzh - 05-17-2014, 04:41 PM
RE: Kirk's 84 - by morzh - 05-17-2014, 06:16 PM
RE: Kirk's 84 - by OldRestorer - 05-17-2014, 07:31 PM
RE: Kirk's 84 - by morzh - 05-17-2014, 08:16 PM
RE: Kirk's 84 - by morzh - 05-17-2014, 10:56 PM
RE: Kirk's 84 - by OldRestorer - 05-18-2014, 06:17 AM
RE: Kirk's 84 - by morzh - 05-18-2014, 11:05 AM
RE: Kirk's 84 - by Ron Ramirez - 05-18-2014, 03:20 PM
RE: Kirk's 84 - by morzh - 05-18-2014, 03:34 PM
RE: Kirk's 84 - by Radioroslyn - 05-18-2014, 05:21 PM
RE: Kirk's 84 - by Ron Ramirez - 05-18-2014, 06:06 PM
RE: Kirk's 84 - by morzh - 05-18-2014, 06:12 PM
RE: Kirk's 84 - by sam - 05-18-2014, 06:18 PM
RE: Kirk's 84 - by morzh - 05-18-2014, 07:46 PM
RE: Kirk's 84 - by morzh - 05-18-2014, 07:52 PM
There are currently 10224 online users. [Complete List]
» 3 Member(s) | 10221 Guest(s)
