TUBE TESTER - WHAT TYPE?
One of the few times in my collecting career that I hit it really lucky - about 25 or so years ago, I attended an estate auction of a radio-TV repair shop. I still have one of the items I bought at that auction, a Heathkit TT-1A mutual conductance tube tester. I think that was the best two dollars I ever spent in this hobby. Icon_biggrin It worked for many years until it began to get flaky a few years ago, at which point I replaced all paper and electrolytic capacitors.
It's still going strong...the meter sticks sometimes now, but a careful tapping gets the pointer loose again.
That said, I concur that for average radio restoration, an emission tester will be good enough.
TUBE TESTER - WHAT TYPE? - by ODPILOT - 05-17-2014, 01:49 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 03:36 PM
RE: TUBE TESTER - WHAT TYPE? - by codefox1 - 05-17-2014, 04:35 PM
RE: TUBE TESTER - WHAT TYPE? - by morzh - 05-17-2014, 04:48 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 05:29 PM
RE: TUBE TESTER - WHAT TYPE? - by Phlogiston - 05-17-2014, 07:26 PM
RE: TUBE TESTER - WHAT TYPE? - by morzh - 05-17-2014, 08:28 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 08:50 PM
RE: TUBE TESTER - WHAT TYPE? - by Eliot Ness - 05-18-2014, 09:15 AM
RE: TUBE TESTER - WHAT TYPE? - by GarySP - 05-18-2014, 07:40 PM
RE: TUBE TESTER - WHAT TYPE? - by Ron Ramirez - 05-18-2014, 08:50 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-19-2014, 12:03 PM
RE: TUBE TESTER - WHAT TYPE? - by Chuck Schwark - 05-19-2014, 03:42 PM
RE: TUBE TESTER - WHAT TYPE? - by Ron Ramirez - 05-19-2014, 03:49 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-19-2014, 05:47 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-19-2014, 10:22 PM
RE: TUBE TESTER - WHAT TYPE? - by Jamie - 05-20-2014, 11:51 AM
RE: TUBE TESTER - WHAT TYPE? - by K7Sparky - 05-21-2014, 12:42 PM
RE: TUBE TESTER - WHAT TYPE? - by Eric T - 05-22-2014, 02:04 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-23-2014, 09:30 AM
RE: TUBE TESTER - WHAT TYPE? - by DeckApe - 05-27-2014, 05:00 PM
RE: TUBE TESTER - WHAT TYPE? - by K7Sparky - 05-27-2014, 07:37 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-27-2014, 09:39 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-27-2014, 10:29 PM
RE: TUBE TESTER - WHAT TYPE? - by Arran - 05-27-2014, 10:44 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-28-2014, 10:44 AM
RE: TUBE TESTER - WHAT TYPE? - by Arran - 05-30-2014, 01:57 AM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-30-2014, 10:16 AM
RE: TUBE TESTER - WHAT TYPE? - by Alan Douglas - 05-31-2014, 09:09 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-31-2014, 10:35 PM
There are currently 11342 online users. [Complete List]
» 2 Member(s) | 11340 Guest(s)
