38-10 Low volume on stations
morzh,
I have also tried another NOS 6A8 and NOS 6Q7 in the chassis (and I already replaced the 6K7). No change in behavior. I did check continuity on the coils way back a few weeks ago when I first started this one. Everything was as expected. These coils have very low resistance on them. Most (if not all) are all "less than .1ohms".
38-10 Low volume on stations - by Nick3092 - 05-18-2014, 09:31 PM
RE: 38-10 Low volume on stations - by gregb - 05-18-2014, 09:40 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 09:50 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 09:51 PM
RE: 38-10 Low volume on stations - by murf - 05-18-2014, 09:52 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 09:56 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 10:12 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 10:18 PM
RE: 38-10 Low volume on stations - by gregb - 05-18-2014, 10:24 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 10:26 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 10:32 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 10:43 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 10:45 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 11:02 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 11:11 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 11:28 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 11:39 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-20-2014, 08:39 PM
RE: 38-10 Low volume on stations - by gregb - 05-20-2014, 08:48 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-20-2014, 09:02 PM
RE: 38-10 Low volume on stations - by TA Forbes - 05-20-2014, 09:56 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-20-2014, 10:07 PM
RE: 38-10 Low volume on stations - by morzh - 05-20-2014, 11:01 PM
There are currently 7023 online users. [Complete List]
» 1 Member(s) | 7022 Guest(s)
