New acquisition, Philco 655B
Very Nice Radio Brian!! Congrats!!! Enjoy the restoration!! Icon_wink
New acquisition, Philco 655B - by BDM - 08-08-2008, 03:13 PM
[No subject] - by etech - 08-08-2008, 03:28 PM
[No subject] - by philco phan - 08-08-2008, 05:13 PM
[No subject] - by BDM - 08-08-2008, 05:48 PM
[No subject] - by Doug Houston - 08-09-2008, 12:32 AM
[No subject] - by BDM - 08-09-2008, 01:02 AM
[No subject] - by Texasrocker - 08-09-2008, 01:55 AM
There are currently 8683 online users. [Complete List]
» 2 Member(s) | 8681 Guest(s)
