TUBE TESTER - WHAT TYPE?
I got lucky too, like Ron, a while back.
[Image: http://www.philcorepairbench.com/images/bench02.jpg]
A local house sale and the lady was selling off hubbies'
tool bench and it had a Hickok 600A, pristine, with Supl. charts,
and foreign cross ref sheets, all for $100.
Icon_eek Needless to say . . .
Tweaked the calib a bit and it's minty. Red tolex coverings
also in VG condition - just minor corner wear.
Chuck
TUBE TESTER - WHAT TYPE? - by ODPILOT - 05-17-2014, 01:49 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 03:36 PM
RE: TUBE TESTER - WHAT TYPE? - by codefox1 - 05-17-2014, 04:35 PM
RE: TUBE TESTER - WHAT TYPE? - by morzh - 05-17-2014, 04:48 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 05:29 PM
RE: TUBE TESTER - WHAT TYPE? - by Phlogiston - 05-17-2014, 07:26 PM
RE: TUBE TESTER - WHAT TYPE? - by morzh - 05-17-2014, 08:28 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-17-2014, 08:50 PM
RE: TUBE TESTER - WHAT TYPE? - by Eliot Ness - 05-18-2014, 09:15 AM
RE: TUBE TESTER - WHAT TYPE? - by GarySP - 05-18-2014, 07:40 PM
RE: TUBE TESTER - WHAT TYPE? - by Ron Ramirez - 05-18-2014, 08:50 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-19-2014, 12:03 PM
RE: TUBE TESTER - WHAT TYPE? - by Chuck Schwark - 05-19-2014, 03:42 PM
RE: TUBE TESTER - WHAT TYPE? - by Ron Ramirez - 05-19-2014, 03:49 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-19-2014, 05:47 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-19-2014, 10:22 PM
RE: TUBE TESTER - WHAT TYPE? - by Jamie - 05-20-2014, 11:51 AM
RE: TUBE TESTER - WHAT TYPE? - by K7Sparky - 05-21-2014, 12:42 PM
RE: TUBE TESTER - WHAT TYPE? - by Eric T - 05-22-2014, 02:04 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-23-2014, 09:30 AM
RE: TUBE TESTER - WHAT TYPE? - by DeckApe - 05-27-2014, 05:00 PM
RE: TUBE TESTER - WHAT TYPE? - by K7Sparky - 05-27-2014, 07:37 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-27-2014, 09:39 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-27-2014, 10:29 PM
RE: TUBE TESTER - WHAT TYPE? - by Arran - 05-27-2014, 10:44 PM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-28-2014, 10:44 AM
RE: TUBE TESTER - WHAT TYPE? - by Arran - 05-30-2014, 01:57 AM
RE: TUBE TESTER - WHAT TYPE? - by TA Forbes - 05-30-2014, 10:16 AM
RE: TUBE TESTER - WHAT TYPE? - by Alan Douglas - 05-31-2014, 09:09 PM
RE: TUBE TESTER - WHAT TYPE? - by jerryhawthorne - 05-31-2014, 10:35 PM
There are currently 10505 online users. [Complete List]
» 3 Member(s) | 10502 Guest(s)
