RECTIFIERs replaced with DIODEs
Other then a few books I have on selenium rectifiers, I haven't seen anything specific about how to replace a given type of tube rectifier, like a 117Z6, 35Z5, with a solid state one. In the case of a 5Y3 I wouldn't even bother, it's a common enough tube that there really isn't any advantage in using a solid state substitute, unless you want higher B+ voltage. Generally speaking when someone is talking about substitute rectifiers it usually involves replacing a worn out selenium rectifier with a silicon rectifier, selenium rectifiers have a higher forward drop then silicon but they are still instant on.
To mimic the operation of a tube one would have to use a current limiter or a thermistor, although with a directly heated tube rectifier they are still almost instant on. The last time I substituted a tube with a silicon rectifier was to replace a 117Z3 in a weird post war radio/phono combo unit, since it was 117 volts (120 volts) it ran directly off the power line.
The other time I substituted a tube with a silicon rectifier was in a brand Z three way portable because I did not have a 117Z6. I needed to add a dropper since the battery tube filaments are run in series with the B+ supply, but the instant on aspect did not matter since battery tubes are pretty well instant on as well.
RECTIFIERs replaced with DIODEs - by Bradley Rush - 05-19-2014, 03:12 AM
RE: RECTIFIERs replaced with DIODEs - by morzh - 05-19-2014, 09:53 AM
RE: RECTIFIERs replaced with DIODEs - by tab10672 - 05-19-2014, 12:37 PM
RE: RECTIFIERs replaced with DIODEs - by tab10672 - 05-19-2014, 01:49 PM
RE: RECTIFIERs replaced with DIODEs - by morzh - 05-19-2014, 05:33 PM
RE: RECTIFIERs replaced with DIODEs - by Arran - 05-19-2014, 09:44 PM
RE: RECTIFIERs replaced with DIODEs - by codefox1 - 05-20-2014, 10:53 AM
RE: RECTIFIERs replaced with DIODEs - by K7Sparky - 05-21-2014, 06:48 PM
RE: RECTIFIERs replaced with DIODEs - by TV MAN - 05-24-2014, 11:25 AM
RE: RECTIFIERs replaced with DIODEs - by David - 05-25-2014, 03:47 PM
RE: RECTIFIERs replaced with DIODEs - by K7Sparky - 05-26-2014, 08:32 AM
RE: RECTIFIERs replaced with DIODEs - by David - 05-27-2014, 02:39 PM
There are currently 6991 online users. [Complete List]
» 1 Member(s) | 6990 Guest(s)
