38 23 philco? (bought it)
What I could never understand about many of these transformerless sets is that they were designed for AC/DC only. Like the schematic for the Pilot that Tom linked to, it has a pair of 25Z5s connected in parallel, when they could have been hooked up as a voltage doubler. Of course with four output tubes the current draw will be higher, but if they used a voltage doubler they could get more performance without having to use 25L6s in Push-Pull parallel. There were also some strange Halson and FADA models that were transformerless but with high tube counts, but again they made them AC/DC only.
The strange part is that the 25Z5, and it's 25Z6 successor, was intended to be used as a voltage doubler but I've never seen them used in that way, though I have heard some odd sets did. For some reason they made most of these sets to accommodate the minority of DC only power grids, a few minor circuit changes and they could have made a high performance transformerless AC design. With some thinking they could have made a change over switch so they could be converted back and fourth, kind of like the voltage changing taps on a European export radio.
38 23 philco? (bought it) - by OldRestorer - 05-14-2014, 12:51 PM
RE: 38 23 philco? - by Ron Ramirez - 05-14-2014, 02:17 PM
RE: 38 23 philco? - by OldRestorer - 05-14-2014, 02:41 PM
RE: 38 23 philco? (bought it) - by Ron Ramirez - 05-14-2014, 02:48 PM
RE: 38 23 philco? (bought it) - by Jayce - 05-14-2014, 06:17 PM
RE: 38 23 philco? (bought it) - by KCMike - 05-15-2014, 03:30 PM
RE: 38 23 philco? (bought it) - by Jayce - 05-15-2014, 09:06 PM
RE: 38 23 philco? (bought it) - by OldRestorer - 05-16-2014, 09:16 AM
RE: 38 23 philco? (bought it) - by KCMike - 05-16-2014, 09:34 AM
RE: 38 23 philco? (bought it) - by PhilcoJohn - 05-17-2014, 07:00 PM
RE: 38 23 philco? (bought it) - by jerryhawthorne - 05-18-2014, 02:36 PM
RE: 38 23 philco? (bought it) - by OldRestorer - 05-18-2014, 02:51 PM
RE: 38 23 philco? (bought it) - by TA Forbes - 05-19-2014, 11:36 AM
RE: 38 23 philco? (bought it) - by Arran - 05-19-2014, 11:27 PM
RE: 38 23 philco? (bought it) - by TA Forbes - 05-20-2014, 09:48 AM
Philco 91 Tuning Condenser
