38 23 philco? (bought it)
I have seen them used as a V-doubler, but agree very uncommon.
Yes, the current requirement would call for two rectifiers. With the P-PP 25L6 output I would imagine that the power output is in the vicinity of 10 watts.
One of the neat things about this hobby is the unique circuit arrangements you encounter.
38 23 philco? (bought it) - by OldRestorer - 05-14-2014, 12:51 PM
RE: 38 23 philco? - by Ron Ramirez - 05-14-2014, 02:17 PM
RE: 38 23 philco? - by OldRestorer - 05-14-2014, 02:41 PM
RE: 38 23 philco? (bought it) - by Ron Ramirez - 05-14-2014, 02:48 PM
RE: 38 23 philco? (bought it) - by Jayce - 05-14-2014, 06:17 PM
RE: 38 23 philco? (bought it) - by KCMike - 05-15-2014, 03:30 PM
RE: 38 23 philco? (bought it) - by Jayce - 05-15-2014, 09:06 PM
RE: 38 23 philco? (bought it) - by OldRestorer - 05-16-2014, 09:16 AM
RE: 38 23 philco? (bought it) - by KCMike - 05-16-2014, 09:34 AM
RE: 38 23 philco? (bought it) - by PhilcoJohn - 05-17-2014, 07:00 PM
RE: 38 23 philco? (bought it) - by jerryhawthorne - 05-18-2014, 02:36 PM
RE: 38 23 philco? (bought it) - by OldRestorer - 05-18-2014, 02:51 PM
RE: 38 23 philco? (bought it) - by TA Forbes - 05-19-2014, 11:36 AM
RE: 38 23 philco? (bought it) - by Arran - 05-19-2014, 11:27 PM
RE: 38 23 philco? (bought it) - by TA Forbes - 05-20-2014, 09:48 AM
Philco 91 Tuning Condenser
There are currently 6459 online users. [Complete List]
» 1 Member(s) | 6458 Guest(s)
