What have I taken on! Silvertone 45 Restoration FINISHED
#31
I drink a little coffee! and 5 hour energy
Today I decided to make the other top side molding.
I used a chisel at first but then quickly decided to use my saw. After 25 minutes digging it out I cut a piece to size and began mimicking the left side piece. Very tedious but came out good.
Some stain and tiny bits of filler should match it well.
I then began fine sanding the cabinet sides and rebuilt the cabinet parts that I had. Next I will build the front and top and then veneer the entire thing.
RE: What have I taken on! - by morzh - 04-18-2014, 02:56 PM
RE: What have I taken on! - by PAradiogeek - 04-18-2014, 07:38 PM
RE: What have I taken on! - by morzh - 04-18-2014, 09:35 PM
RE: What have I taken on! - by 37silverstreak - 04-18-2014, 09:46 PM
RE: What have I taken on! - by radiohenry - 04-19-2014, 07:43 AM
RE: What have I taken on! - by BrendaAnnD - 04-19-2014, 11:21 AM
RE: What have I taken on! - by morzh - 04-19-2014, 12:22 PM
RE: What have I taken on! - by codefox1 - 04-19-2014, 01:35 PM
RE: What have I taken on! - by OldRestorer - 04-19-2014, 11:26 PM
RE: What have I taken on! - by bobk9eui - 04-20-2014, 10:36 AM
RE: What have I taken on! - by BrendaAnnD - 04-20-2014, 12:27 PM
RE: What have I taken on! - by Jamie - 04-20-2014, 01:29 PM
RE: What have I taken on! - by morzh - 04-20-2014, 02:45 PM
RE: What have I taken on! - by OldRestorer - 04-20-2014, 03:47 PM
RE: What have I taken on! - by morzh - 04-20-2014, 03:57 PM
RE: What have I taken on! - by Eliot Ness - 04-20-2014, 04:45 PM
RE: What have I taken on! - by morzh - 04-20-2014, 05:59 PM
RE: What have I taken on! - by radiohenry - 04-20-2014, 11:15 PM
RE: What have I taken on! - by murf - 04-21-2014, 05:54 PM
RE: What have I taken on! - by Eliot Ness - 04-21-2014, 07:34 PM
RE: What have I taken on! - by OldRestorer - 04-21-2014, 08:19 PM
RE: What have I taken on! - by Eliot Ness - 04-21-2014, 09:01 PM
RE: What have I taken on! - by rocklandman - 04-22-2014, 01:42 PM
RE: What have I taken on! - by Eliot Ness - 04-22-2014, 04:54 PM
RE: What have I taken on! - by TimC - 04-22-2014, 05:11 PM
RE: What have I taken on! - by OldRestorer - 04-22-2014, 05:20 PM
RE: What have I taken on! - by OldRestorer - 04-22-2014, 05:55 PM
RE: What have I taken on! Restoration Begun - by OldRestorer - 05-20-2014, 02:43 PM
There are currently 4798 online users. [Complete List]
» 1 Member(s) | 4797 Guest(s)
