Philco 2W resistors mystery
Quote:Kits are expensive.
if you know values you want, just make a list and go to Mouser.
Well, that's just it... I don't want to have to make a special order all the time. I like to have the replacements on hand. I usually try to buy in bulk, so I have a nice stock of parts that are ready to use. I have about 10 of every value resistor, but they are all 1/2w. Same with caps - I have most values. I have founds that the kits from Justradios are a good savings instead of buying one piece at a time. I just wish he offered a 2w kit too.
Philco 2W resistors mystery - by morzh - 05-17-2014, 11:06 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-18-2014, 09:56 AM
RE: Philco 2W resistors mystery - by TA Forbes - 05-18-2014, 10:07 AM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 11:03 AM
RE: Philco 2W resistors mystery - by Ron Ramirez - 05-18-2014, 03:25 PM
RE: Philco 2W resistors mystery - by Radioroslyn - 05-18-2014, 05:26 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-18-2014, 06:01 PM
RE: Philco 2W resistors mystery - by Ron Ramirez - 05-18-2014, 06:02 PM
RE: Philco 2W resistors mystery - by PAradiogeek - 05-18-2014, 07:25 PM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 07:41 PM
RE: Philco 2W resistors mystery - by GarySP - 05-18-2014, 07:44 PM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 07:53 PM
RE: Philco 2W resistors mystery - by Jamie - 05-20-2014, 12:17 PM
RE: Philco 2W resistors mystery - by morzh - 05-20-2014, 01:21 PM
RE: Philco 2W resistors mystery - by gregb - 05-20-2014, 02:35 PM
RE: Philco 2W resistors mystery - by Jamie - 05-20-2014, 03:37 PM
RE: Philco 2W resistors mystery - by TA Forbes - 05-20-2014, 09:51 PM
RE: Philco 2W resistors mystery - by Raleigh - 05-24-2014, 05:49 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-26-2014, 08:04 AM
RE: Philco 2W resistors mystery - by Joeztech - 06-01-2014, 09:29 PM
RE: Philco 2W resistors mystery - by Arran - 06-01-2014, 10:32 PM
There are currently 10522 online users. [Complete List]
» 2 Member(s) | 10520 Guest(s)
