38-10 Low volume on stations
I tried another NOS 6A8, same result. In the past, based on someone's suggestion, I put the original 6A8 into a known working radio in place of the second radio's 6J8. The second radio worked fine with the original 6A8 in it.
38-10 Low volume on stations - by Nick3092 - 05-18-2014, 09:31 PM
RE: 38-10 Low volume on stations - by gregb - 05-18-2014, 09:40 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 09:50 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 09:51 PM
RE: 38-10 Low volume on stations - by murf - 05-18-2014, 09:52 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 09:56 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 10:12 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 10:18 PM
RE: 38-10 Low volume on stations - by gregb - 05-18-2014, 10:24 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 10:26 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 10:32 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 10:43 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 10:45 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 11:02 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 11:11 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 11:28 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 11:39 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-20-2014, 08:39 PM
RE: 38-10 Low volume on stations - by gregb - 05-20-2014, 08:48 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-20-2014, 09:02 PM
RE: 38-10 Low volume on stations - by TA Forbes - 05-20-2014, 09:56 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-20-2014, 10:07 PM
RE: 38-10 Low volume on stations - by morzh - 05-20-2014, 11:01 PM
