15 (X) tubes
They are out there for much less than 45.00.
In fact, I don't believe that I have ever paid more than 10.00 for an NOS one.
45.00 is more like you would pay for a globe 42.
15 (X) tubes - by Phlogiston - 05-18-2014, 07:10 PM
RE: 15 (X) tubes - by Mondial - 05-18-2014, 08:38 PM
RE: 15 (X) tubes - by Ron Ramirez - 05-18-2014, 08:43 PM
RE: 15 (X) tubes - by klondike98 - 05-18-2014, 10:24 PM
RE: 15 (X) tubes - by gregb - 05-18-2014, 11:49 PM
RE: 15 (X) tubes - by Phlogiston - 05-19-2014, 10:47 AM
RE: 15 (X) tubes - by TA Forbes - 05-19-2014, 11:24 AM
RE: 15 (X) tubes - by Arran - 05-20-2014, 09:44 PM
RE: 15 (X) tubes - by TA Forbes - 05-20-2014, 09:49 PM
RE: 15 (X) tubes - by gregb - 05-20-2014, 11:26 PM
RE: 15 (X) tubes - by Phlogiston - 05-21-2014, 02:22 AM
RE: 15 (X) tubes - by gregb - 05-21-2014, 08:47 AM
RE: 15 (X) tubes - by Bob Andersen - 05-24-2014, 02:57 PM
Philco 91 Tuning Condenser
There are currently 4808 online users. [Complete List]
» 2 Member(s) | 4806 Guest(s)
