38-10 Low volume on stations
Nick: assume you are injecting minimal signal amplitude when doing an alignment? Too high an amplitude will cause the AVC to flame on and screw up your alignment.
Have you disabled the AVC and seen what the result is?
38-10 Low volume on stations - by Nick3092 - 05-18-2014, 09:31 PM
RE: 38-10 Low volume on stations - by gregb - 05-18-2014, 09:40 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 09:50 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 09:51 PM
RE: 38-10 Low volume on stations - by murf - 05-18-2014, 09:52 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 09:56 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 10:12 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 10:18 PM
RE: 38-10 Low volume on stations - by gregb - 05-18-2014, 10:24 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 10:26 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 10:32 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 10:43 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 10:45 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 11:02 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 11:11 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-18-2014, 11:28 PM
RE: 38-10 Low volume on stations - by morzh - 05-18-2014, 11:39 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-20-2014, 08:39 PM
RE: 38-10 Low volume on stations - by gregb - 05-20-2014, 08:48 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-20-2014, 09:02 PM
RE: 38-10 Low volume on stations - by TA Forbes - 05-20-2014, 09:56 PM
RE: 38-10 Low volume on stations - by Nick3092 - 05-20-2014, 10:07 PM
RE: 38-10 Low volume on stations - by morzh - 05-20-2014, 11:01 PM
There are currently 8339 online users. [Complete List]
» 2 Member(s) | 8337 Guest(s)
