philco bakelite blocks
Not only does it keep it looking original, it also makes it a neater, cleaner, more organized electronic restoration job.
Ed M.
philco bakelite blocks - by Chris Drumma - 12-04-2005, 03:40 PM
[No subject] - by Chuck Schwark - 12-04-2005, 03:54 PM
[No subject] - by Chris Drumma - 12-04-2005, 04:24 PM
[No subject] - by Ron Ramirez - 12-04-2005, 05:05 PM
[No subject] - by Poston Drake - 12-07-2005, 01:26 PM
[No subject] - by don'tdomelikethat - 12-07-2005, 07:15 PM
[No subject] - by Guest - 12-08-2005, 10:14 PM
[No subject] - by Ron Ramirez - 12-08-2005, 10:44 PM
[No subject] - by Chuck Schwark - 12-09-2005, 12:32 AM
[No subject] - by Ron Ramirez - 12-09-2005, 01:42 AM
[No subject] - by Poston Drake - 12-09-2005, 11:19 AM
[No subject] - by Ron Ramirez - 12-09-2005, 12:52 PM
There are currently 9175 online users. [Complete List]
» 2 Member(s) | 9173 Guest(s)
