philco 90 ecap question
A single capacitor won't work. Number 56, the input capacitor connects positive to the 80 filament and to the input of the filter choke, negative to the HV center tap. Number 57 connects positive to the output of the filter choke and negative to chassis ground.
M R Radios   C M Tubes
philco 90 ecap question - by bdi1976 - 05-20-2014, 10:10 PM
RE: philco 90 ecap question - by Steve Davis - 05-20-2014, 10:29 PM
RE: philco 90 ecap question - by Mondial - 05-20-2014, 10:29 PM
RE: philco 90 ecap question - by bdi1976 - 05-21-2014, 03:44 PM
RE: philco 90 ecap question - by Ron Ramirez - 05-21-2014, 05:37 PM
RE: philco 90 ecap question - by bdi1976 - 05-21-2014, 06:37 PM
RE: philco 90 ecap question - by Ron Ramirez - 05-21-2014, 07:22 PM
There are currently 11232 online users. [Complete List]
» 2 Member(s) | 11230 Guest(s)
