I finally finished my 66B
The electronics were done this winter, including all of the Bakelite blocks (thanks to many tips from Phorum members). I've been waiting for some nice weather to finish the cabinet.
I had to replace the veneer on both sides and the top. I finished it with Mohawk toners. Medium Brown Walnut and Van Dyke Brown for the trim. The grill cloth is a repro that is somewhat close to original.
Eric
The Villages, FL
I finally finished my 66B - by Eric Adams - 05-21-2014, 12:19 AM
RE: I finally finished my 66B - by OldRestorer - 05-21-2014, 08:20 AM
RE: I finally finished my 66B - by Eric Adams - 05-21-2014, 09:01 AM
RE: I finally finished my 66B - by morzh - 05-21-2014, 09:32 AM
RE: I finally finished my 66B - by gregb - 05-21-2014, 09:45 AM
RE: I finally finished my 66B - by AI2V - 05-21-2014, 10:32 AM
RE: I finally finished my 66B - by PAradiogeek - 05-21-2014, 11:58 AM
RE: I finally finished my 66B - by Eric Adams - 05-21-2014, 01:25 PM
RE: I finally finished my 66B - by Warren - 05-21-2014, 05:26 PM
RE: I finally finished my 66B - by KCMike - 05-21-2014, 06:12 PM
RE: I finally finished my 66B - by 462ron - 05-21-2014, 07:38 PM
RE: I finally finished my 66B - by Eric Adams - 05-21-2014, 11:09 PM
RE: I finally finished my 66B - by Paul Philco322 - 05-22-2014, 07:07 PM
RE: I finally finished my 66B - by codefox1 - 05-22-2014, 09:08 PM
RE: I finally finished my 66B - by PhilcoJohn - 05-23-2014, 06:26 AM
RE: I finally finished my 66B - by klondike98 - 05-23-2014, 12:13 PM
Philco 91 Tuning Condenser
