Identify Radio
Just purchased a Philco 6 tube radio not sure of the Model
number but it could be M-936-124 Its about a 57 thru 59 model .it uses the
small tubes..50c5,12bag,12bag,12avg,12beg and 17c9 Its a long wooded
case that sits on two plastic runners as legs with twin speakers, have a picture but not sure how to up load...tanks for any help
Identify Radio - by Guest - 08-09-2008, 02:34 PM
[No subject] - by Chuck Schwark - 08-10-2008, 07:38 PM
There are currently 9945 online users. [Complete List]
» 2 Member(s) | 9943 Guest(s)
