Coil rewinding?
Morzh
That was a general question. RF transformer/tuner with adjustable compensator. As I mentioned earlier, had to delete compensator completely to achieve max. output. Suspect the coil.
However.. here it is:
http://www.nostalgiaair.org/PagesByModel...013881.pdf
Coil rewinding? - by fields 100 - 05-21-2014, 08:39 AM
RE: Coil rewinding? - by morzh - 05-21-2014, 09:36 AM
RE: Coil rewinding? - by fields 100 - 05-21-2014, 10:27 AM
RE: Coil rewinding? - by morzh - 05-21-2014, 10:58 AM
RE: Coil rewinding? - by fields 100 - 05-22-2014, 04:28 PM
RE: Coil rewinding? - by Mondial - 05-22-2014, 05:06 PM
RE: Coil rewinding? - by morzh - 05-22-2014, 05:21 PM
RE: Coil rewinding? - by fields 100 - 05-22-2014, 06:26 PM
RE: Coil rewinding? - by fields 100 - 05-22-2014, 07:35 PM
RE: Coil rewinding? - by Mondial - 05-22-2014, 08:24 PM
