Coil rewinding?
Yes, it is antenna coil. Dial is at 1400kc.Sig. gen at 1400kc. HF osc. aligns OK with it's compensator.. Next is 1st det. at 1400kc-OK. Then 2d antenna- that is where the issue is. Deleted that compensator. Without compensator alignment is OK. The dial still at 1400kc. Next is 1st antenna-aligns OK. Even if the dial was in the wrong position, which I do not think it is, why then 3 other compensators allowed adjustment at 1400kc being fed from the generator with the same dial setting?
Coil rewinding? - by fields 100 - 05-21-2014, 08:39 AM
RE: Coil rewinding? - by morzh - 05-21-2014, 09:36 AM
RE: Coil rewinding? - by fields 100 - 05-21-2014, 10:27 AM
RE: Coil rewinding? - by morzh - 05-21-2014, 10:58 AM
RE: Coil rewinding? - by fields 100 - 05-22-2014, 04:28 PM
RE: Coil rewinding? - by Mondial - 05-22-2014, 05:06 PM
RE: Coil rewinding? - by morzh - 05-22-2014, 05:21 PM
RE: Coil rewinding? - by fields 100 - 05-22-2014, 06:26 PM
RE: Coil rewinding? - by fields 100 - 05-22-2014, 07:35 PM
RE: Coil rewinding? - by Mondial - 05-22-2014, 08:24 PM
There are currently 10224 online users. [Complete List]
» 3 Member(s) | 10221 Guest(s)
