Coil rewinding?
@ Mondial,
Interesting idea, it might work.So, when I detune (increase HF osc. compensator capacitance),should I chase 1400kc from generator by means of moving the dial away from 1400kc setting until I get the highest output on my meter?
Coil rewinding? - by fields 100 - 05-21-2014, 08:39 AM
RE: Coil rewinding? - by morzh - 05-21-2014, 09:36 AM
RE: Coil rewinding? - by fields 100 - 05-21-2014, 10:27 AM
RE: Coil rewinding? - by morzh - 05-21-2014, 10:58 AM
RE: Coil rewinding? - by fields 100 - 05-22-2014, 04:28 PM
RE: Coil rewinding? - by Mondial - 05-22-2014, 05:06 PM
RE: Coil rewinding? - by morzh - 05-22-2014, 05:21 PM
RE: Coil rewinding? - by fields 100 - 05-22-2014, 06:26 PM
RE: Coil rewinding? - by fields 100 - 05-22-2014, 07:35 PM
RE: Coil rewinding? - by Mondial - 05-22-2014, 08:24 PM
Philco 91 Restore Code ??
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
There are currently 3236 online users. [Complete List]
» 4 Member(s) | 3232 Guest(s)
AvatarAvatarAvatarAvatar
