Westinghouse WR-10A
Thanks for the info Doug. Unless it was some kind of factory option, I planned to remove it. To bad they installed that darned pot on the front panel. I think I can repair it though. This radio is the WR10A version with the 47 tubes in it. At least the 47's are reasonably priced.
BTW, I also have a GE S-22A which is nearing completion. I have refinished the cabinet and was waiting for a new power transformer. I finally got one and the radio is playing nicely now. It is the same chassis as the WR-10A, using the 47's.
Ed
Westinghouse WR-10A - by etech - 07-25-2008, 08:32 PM
[No subject] - by Texasrocker - 07-26-2008, 12:15 AM
[No subject] - by etech - 07-26-2008, 01:56 PM
[No subject] - by Texasrocker - 07-27-2008, 01:47 AM
[No subject] - by Doug Houston - 08-09-2008, 01:05 AM
[No subject] - by etech - 08-09-2008, 07:36 PM
[No subject] - by Doug Houston - 08-09-2008, 09:15 PM
[No subject] - by etech - 08-09-2008, 09:44 PM
[No subject] - by Texasrocker - 08-17-2008, 03:27 AM
Eico 232 VTVM Schematic
There are currently 10279 online users. [Complete List]
» 1 Member(s) | 10278 Guest(s)
