Philco 90 - another error?
Hi forum,
I am close to finished the 90. I found a strange thing that is either an error which I have not heard about or a complete coincidence. Part number 1 (10 Kohms resistor) reads 10 Ohms. It is an original dogbone. Should this be 10K or 10 ohms...or is this a possible error? After hearing about the schematic mistakes, nothing would surprise me. Thanks fellas- I'll put a pic of her up once she's singing-
BDI
Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:08 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:13 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:17 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:31 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:33 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:35 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:41 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:48 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:52 PM
There are currently 6099 online users. [Complete List]
» 4 Member(s) | 6095 Guest(s)
AvatarAvatarAvatarAvatar
