Philco 90 - another error?
not that stupid...remember i'm still learning. It is connected to the coil, but i'm reading it at the ends of the resistor, bypassing the coil. Will the coil affect the reading?
Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:08 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:13 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:17 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:31 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:33 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:35 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:41 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:48 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:52 PM
There are currently 10841 online users. [Complete List]
» 2 Member(s) | 10839 Guest(s)
