Philco 90 - another error?
Well, the good news is, your antenna coil is OK. At least this one.
Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:08 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:13 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:17 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:31 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:33 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:35 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:41 PM
RE: Philco 90 - another error? - by bdi1976 - 05-23-2014, 09:48 PM
RE: Philco 90 - another error? - by morzh - 05-23-2014, 09:52 PM
There are currently 10676 online users. [Complete List]
» 1 Member(s) | 10675 Guest(s)
