Philco 2W resistors mystery
Years ago I bought the 1/2 watt kit from Radio Daze and the 1 watt kit from AES. I've occasionally put 2 or even 3 resistors in series when I need a larger wattage resistor than I have on hand. Unless the space is too tight, that usually works fine. I try to use values that are close if not the same, so I split the power more or less evenly.
By the way, Just Radios now offers 2W kits in metal oxide and carbon film types. They also have a 5 W wire wound kit.
I too like having the supplies on hand so I don't have to wait for an order to come it. It's nice to have 'em if I need 'em. I'm not sure the kits are really a good value, though, because there are many, many values I never use at all.
John Honeycutt
Philco 2W resistors mystery - by morzh - 05-17-2014, 11:06 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-18-2014, 09:56 AM
RE: Philco 2W resistors mystery - by TA Forbes - 05-18-2014, 10:07 AM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 11:03 AM
RE: Philco 2W resistors mystery - by Ron Ramirez - 05-18-2014, 03:25 PM
RE: Philco 2W resistors mystery - by Radioroslyn - 05-18-2014, 05:26 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-18-2014, 06:01 PM
RE: Philco 2W resistors mystery - by Ron Ramirez - 05-18-2014, 06:02 PM
RE: Philco 2W resistors mystery - by PAradiogeek - 05-18-2014, 07:25 PM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 07:41 PM
RE: Philco 2W resistors mystery - by GarySP - 05-18-2014, 07:44 PM
RE: Philco 2W resistors mystery - by morzh - 05-18-2014, 07:53 PM
RE: Philco 2W resistors mystery - by Jamie - 05-20-2014, 12:17 PM
RE: Philco 2W resistors mystery - by morzh - 05-20-2014, 01:21 PM
RE: Philco 2W resistors mystery - by gregb - 05-20-2014, 02:35 PM
RE: Philco 2W resistors mystery - by Jamie - 05-20-2014, 03:37 PM
RE: Philco 2W resistors mystery - by TA Forbes - 05-20-2014, 09:51 PM
RE: Philco 2W resistors mystery - by Raleigh - 05-24-2014, 05:49 PM
RE: Philco 2W resistors mystery - by codefox1 - 05-26-2014, 08:04 AM
RE: Philco 2W resistors mystery - by Joeztech - 06-01-2014, 09:29 PM
RE: Philco 2W resistors mystery - by Arran - 06-01-2014, 10:32 PM
There are currently 10829 online users. [Complete List]
» 2 Member(s) | 10827 Guest(s)
