Vibrator Cross Reference?
I found that one a month ago too.. but trying to find any of the three is proving to take some time. Icon_smile
I've even got saved searches on ebay. someone mentioned a wiring change to use other vibrators. wish I knew the pin outs of these vibrators without having to cut them open.
Vibrator Cross Reference? - by bfrohwein - 04-22-2014, 08:23 PM
RE: Vibrator Cross Reference? - by Carl Travis - 04-23-2014, 03:43 PM
RE: Vibrator Cross Reference? - by K7Sparky - 04-23-2014, 04:14 PM
RE: Vibrator Cross Reference? - by gregb - 04-23-2014, 05:34 PM
RE: Vibrator Cross Reference? - by bfrohwein - 04-23-2014, 05:37 PM
RE: Vibrator Cross Reference? - by K7Sparky - 04-28-2014, 06:57 PM
RE: Vibrator Cross Reference? - by K7Sparky - 05-25-2014, 03:43 PM
RE: Vibrator Cross Reference? - by bfrohwein - 05-25-2014, 05:29 PM
RE: Vibrator Cross Reference? - by K7Sparky - 05-25-2014, 07:19 PM
RE: Vibrator Cross Reference? - by bfrohwein - 05-25-2014, 10:26 PM
RE: Vibrator Cross Reference? - by joybird - 05-27-2014, 03:32 PM
There are currently 10780 online users. [Complete List]
» 3 Member(s) | 10777 Guest(s)
