  • 1 Vote(s) - 1 Average
Philco 38-7 Radiobar Restoration
Folks,
I recently purchased a beautiful excellent condition Radiobar cabinet, without any radio chassis, but a label inside calls for a Philco model 38-7, as the installed unit. Fair enough. The question I have is: which chassis is the correct one for this model? The front dial face is mounts vertically for the Radiobar. The 38-7 console model has the 25+ degree (eyeball estimate) offset for easy viewing. If I bought a table cabinet "T" with the 121 chassis, would this work? Or am I looking at the 124 chassis? I do not have one to check against the Radiobar. I need your collective expert guidance
St Tee
Philco 38-7 Radiobar Restoration - by St Tee - 05-26-2014, 12:00 AM
RE: Philco 38-7 Radiobar Restoration - by Arran - 05-26-2014, 03:22 AM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 05-26-2014, 12:04 PM
RE: Philco 38-7 Radiobar Restoration - by voroush - 05-26-2014, 05:26 PM
RE: Philco 38-7 Radiobar Restoration - by Arran - 05-26-2014, 09:44 PM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 05-28-2014, 01:09 AM
RE: Philco 38-7 Radiobar Restoration - by Arran - 05-28-2014, 01:32 AM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 05-28-2014, 04:49 PM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 05-29-2014, 11:38 AM
RE: Philco 38-7 Radiobar Restoration - by Arran - 05-30-2014, 01:34 AM
RE: Philco 38-7 Radiobar Restoration - by St Tee - 06-07-2014, 03:05 PM
RE: Philco 38-7 Radiobar Restoration - by morzh - 06-07-2014, 09:17 PM
RE: Philco 38-7 Radiobar Restoration - by Arran - 06-07-2014, 09:51 PM
RE: Philco 38-7 Radiobar Restoration - by morzh - 06-07-2014, 10:15 PM
There are currently 7131 online users. [Complete List]
» 1 Member(s) | 7130 Guest(s)
