Speaker for a 38-62
Greg, it actually worked and didn't sound too bad.
Jerry
Speaker for a 38-62 - by AJboy123 - 05-19-2014, 04:08 PM
RE: Speaker for a 38-62 - by jerryhawthorne - 05-20-2014, 03:43 PM
RE: Speaker for a 38-62 - by Ron Ramirez - 05-20-2014, 04:45 PM
RE: Speaker for a 38-62 - by AJboy123 - 05-20-2014, 04:51 PM
RE: Speaker for a 38-62 - by jerryhawthorne - 05-20-2014, 07:05 PM
RE: Speaker for a 38-62 - by AJboy123 - 05-20-2014, 08:54 PM
RE: Speaker for a 38-62 - by jerryhawthorne - 05-20-2014, 11:47 PM
RE: Speaker for a 38-62 - by jerryhawthorne - 05-23-2014, 05:00 PM
RE: Speaker for a 38-62 - by AJboy123 - 05-26-2014, 07:29 PM
RE: Speaker for a 38-62 - by gregb - 05-26-2014, 07:50 PM
RE: Speaker for a 38-62 - by jerryhawthorne - 05-26-2014, 09:35 PM
RE: Speaker for a 38-62 - by gregb - 05-26-2014, 10:58 PM
