D-10A confusion
Will compare my D-10 and D-10 service manuals and get back to you this evening. At work right now. I don't believe the later A version used a mag pickup, but memory could be rusty.
Chuck
D-10A confusion - by wise65vw - 05-27-2014, 12:55 AM
RE: D-10A confusion - by Chuck Schwark - 05-27-2014, 09:45 AM
RE: D-10A confusion - by brownie45 - 05-27-2014, 12:42 PM
RE: D-10A confusion - by Chuck Schwark - 05-27-2014, 06:53 PM
RE: D-10A confusion - by wise65vw - 05-28-2014, 09:51 PM
There are currently 11217 online users. [Complete List]
» 2 Member(s) | 11215 Guest(s)
